Project 200sx
Just thought I'd let you's in on one of my wee Projects! I always wanted an S13 200sx for the Track-Drift days! Didn't want it to be perfect cause I really just wanted to have fun and enjoy driving the balls out of it without the worry of wrecking it :inot
Here is a few pics of the build! Sorry I am missing a few....
Ahhhhh.... Ebay £800! The way the project started.
Then 5 Stub Conversion! 4 x 114.3 to 5 x 114.3 et 38
The the important bit... A full engine rebuild... Stage 3 Conversion!
T28rs Turbo upgrade!
Homemade actuator bracket for the T28 Turbo..
First bodykit and car resprayed in Honda Championship White
Just out of the bodyshop, with 17" Rota rims... and decided she needed new rims and rubber.
New rims! Oh yeah! SSR Professors! 11" wide on the rear! 6" dish. Huge stretch on the tyres!
Tryin on the rear rims to see if they are actually gonna fit hahahaha.... A little arch rolling!
So much more to come!
Engine Spec list..
Ca1800DET motor
Steel Internals
Steel Head Gasket
Stainless Steel Manifold
Stainless Steel down pipe and Screamer Pipe
Stainless steel 3" system
555cc Injectors
Z32 Airflow Meter
Z32 Throttle body
Horsham Developments Stage 3 ECU
T28rs Turbo
Nismo Air Filter
24x12x3" Intercoller and hard pipes
B&M Shortshift
Battery relocated
Earthing Kit
Relocated oil filter
Front & Rear strut braces
Coilovers
Monkey Bar
Usual Boost/oil pressure/temp gauges
Paddle Clutch
Running 391BHP @ 17PSI
Loads more to come......
Cheers for looking
Jamesy
Just thought I'd let you's in on one of my wee Projects! I always wanted an S13 200sx for the Track-Drift days! Didn't want it to be perfect cause I really just wanted to have fun and enjoy driving the balls out of it without the worry of wrecking it :jerkit
Engine Spec list..
Ca1800DET motor
Steel Internals
Steel Head Gasket
555cc Injectors
Z32 Airflow Meter
Z32 Throttle body
T28rs Turbo
Nismo Air Filter
B&M Shortshift
Battery relocated
Earthing Kit
Coilovers
Monkey Bar
Paddle Clutch
Cheers for looking
Jamesy
nice .It needs some platinum plus 20% tint
