09 chevy silverado ext cab
Stang04GT
Guest TommyJ
if your having a problem with the "things the bolts screw into" just pull them out and squezze them together with pliers. that tightens them up so they will hold there place. A real pita if you don't do it that way.
Quick tip on "those things that the bolts screw into"... They tend to move around thus making lining up the bolt hole upon putting the panel back on difficult. Bas mentioned above either take them out and squeeze them with pliers to tighten them up or take a small drop of that epoxy and put on the edge then a quick spritz of the insta cure and walla problem solved takes les than 30 seconds.
Can't remember if the newer silvys have shifting windows like the older ones do, but if they do, make sure you cut farther along the back of the window or youll have a light gap
    5. 4
    6. 0
    7. 1
    8. 1
    9. 6
