1992 Honda Accord
Guest tint51
Exactly! :beer
right on he posted this once before and he was told to move it down? lol...I would of moved it up the glass like you suggested....
I would like to add that with light preasure you can slide the fingers to the left or right which will help get them to a area that is not been heated yet. sarah is starting to get the hang of this.."moving the fingers left and right to be able to shrink it more consistant"....."good job Girly"
Thanks TTS, it worked about 99% better.. almost have it down only have a small crease at bottom...
Now for the real thing...
on real light creases you can some times pull the film up wet and reshrink it away......but not hard creases
Guest tint51
Exactly! :beer
Thank you for the tip Also....
I will put that in my memory for later....
:beer
Jeff gave some great advice about if you get a little/slight crease. Sometimes you can puch a little air pocket under it and hit with a touch of heat to re-shrink that spot and make the crease disappear...
Guest tint51
:beer
I did not have completion of back glass.. Did it in 35% but could not get it in 5%.. Will go and Review some videos and comeback and try again..
Thanks, for all the Info...
Tint51
    3. 4
    4. 4
    6. 4
    8. 4
    9. 4
    10. 4
