@Tintguy1980 pretty much covered the difference in the films. Since Ceramic films absorb the heat, the vehicle must be in motion to push the hot air away. No motion means more heat building up in the glass and radiating inward to you. Since Crystalline redirects heat away, the radiating inward heat is much less if you are in traffic or sitting still.
As far as the shop, they either don't want to stock Crystalline since it is $$$$ per roll or do not want to install it since it takes more work and time. Also, not all 3M dealers can install Crystalline. If you check the dealer locator, if they do not have "Crystalline Preferred" listed, then this is most likely the case.
With that being said, we absolutely love the Ceramic IR line, so you can't go wrong there.
I should reach out to graphtec about this issue, but I'm curious if anyone else has experienced the same problem with their plotter. My graphtec plotter can cut specific designs flawlessly without any problems with pressure or shape. Occasionally I experience an issue where I will plot a design consisting of two fronts or a rear windshield window, and the cut is flawless, but just before the plotter finishes, allowing me to remove the excess material from the machine. It reaches the end as if it will finish feeding it completely and then abruptly lowers the blade as if it still needs to cut the design, slicing right through the pattern it just created. Do you have any thoughts on why that occurs?
Selling a like new Jaguar VLX 40" plotter. Works perfectly, we upgraded to another plotter and don't have space for this one.
Only available for pickup, located in Orange County. If interested or you have any questions please contact us at 949-888-6581.
Priced at $3,800 OBO.
Easy technical explanation of the difference between Crystalline and regular 'ceramic' labeled products, including 3Ms:
Crystalline is designed to 'reflect' NIR (Near Infrared, the sun's energy we 'feel' first) as opposed to 'ceramic' products absorbing. Absorbing translates into feeling the sun's energy radiating off the window as your arm is rested next to it. Therefore, Crystalline is superior to ceramics. This is the pitch I would make to you as a buyer.
Maybe the dealer you spoke with simply doesn't want to pay the price for a roll of the product.
I've had Crystalline 40 on my front door glass for 8 yrs now and it shows zero sign of any degradation in color, performance and clarity.
Crystalline would be better than AIR80 for the windshield as well.
I just got off the phone with a 3m dealer in Dallas and he strongly advised me to save my money and get their regular ceramic and not the 3M Crystalline. He said I'd never know the difference and acted like it was NOTHING more than a marketing strategy.
So that's got me all confused. He could make more money off me, but I feel like he's being honest and I appreciate that. But, then I hear everywhere else how much better Crystalline is over other products.
So, I'm still debating on Air 80 or Crystalline for the windshield and Llumar IRx or Formula 1 or 3m Crystalline for the other windows.. So much to consider!
FYI, I generally like the best for a couple hundred more, BUT I do want there to be some improvement.
Welcome to the forum!
I would recommend Global non-cap ppf and get a second bottle with plain water only to flush the edges for better adhesion.
If you're leaving water behind try using a different squeegee. I prefer a dark yellow turbo from Interwest.
Instead of heating I think you should be streaching the film into place to pull the fingers out.
Y'all try not to get too excited, but this is the four cylinder Suzuki version of the Geo Metro with a whopping 1.3L. No ac or power steering but getting 45mpg on 13" rims.
Thanks for the reply! I will see what happens. I tested the paint on a scrap of PPF I had sitting around, the it seems really secure. Just for perspective, I attached a photo of my goof. It really was a small divot, just bugged me that I did it at all. I did place a very small bit of paint on the top of the exposure. Living in MN, rust is always the concern, so I am hoping I have this sealed. While I know that PPF can't heal a cut like this, it was very flat so the exposure should hopefully be minimal.
(What looks like a fold is the reflection of a seam in the ceiling)
