2009 Honda Accord 4dr
Guest Alcala
front quaters are on fit and civic, not accord....does have rear quaters
dry shrink the back glass with powder,dryer sheet, or bar soap..do some research on dry shrinking....the rear glass should take the most of your time..there isnt alot of curve but enough to cause some trouble..you can sand the defrost with 2000 and it will stick better, depending on the type of film you use?
the rear quarters you could use more slip solution to tuck it behind the rubber, doing those last if you change the solution for those? if you have black vynal you could easly use the scrap from your cut to black out the area on the outside and not worry about tucking them...or leave it clear doesnt look bad either way...
on that note you shouldnt have any troubles and if you do? you know where to ask..here on tintdude
all these years, and I've never thought about doing the quarters last :beer I always have had two bottles, one normal and one stronger for back glass's/quarters like fusions/accords. I usually use one bottle total per car, so it would be smart to do the doors first and then add a tad more soap for the rest. durrrrr :spit
funny funny guy mr I dont know...read it again and you might understand...I never said this is how I do them! a rookie would want more slip to tuck quaters behind the rubbers on these quarters
Why pull the panels when it's totally un-neccessary
because it's a few screws and they pop right off. it would take longer to try and tuck the film properly & squeegee it than it would to actually just pull the panel. atleast for me. :bingo
because it's a few screws and they pop right off. it would take longer to try and tuck the film properly squeegee it than it would to actually just pull the panel. atleast for me. :bingo
I agree did them the other day.. a few screws about 5 mins and you are clear... :bingo
Guest a1wintinter
I do Accords everyday and dont use steel wool or pull off the panels, and I never have any trouble with them. However it is much easier to use a couple of fiber sticks and pry the top of the door panels back, then use the fiber sticks on each side of the panel to make some room at the top of the panel.
About the same time .... :bingo
Guest a1wintinter
a little faster for me, no need to shrink the doors
    2. 1
    3. 7
    5. 7
    6. 1
    7. 7
    8. 7
    9. 0
    10. 7
