need a tip on resetting airbag light
Guest John Castelli
Did you cycle the key while the seat was out??
Nissans and other Asian cars usually only set a code if the key is cycled while the yellow pigtail in unplugged.
Try unhooking the batt for a few minutes and driving it through about 3 start cycles and sometimes they will reset themselves...
Look out for the late model the Dodges and Chrysler's, you have to torque the seat bolts to the floor or it will set off the light and the occupant sensor has to be reprogrammed... :lol2
Good Luck:cool
