Acura TSX
oldtinter
Guest staudy
Quick question on felting - the rubber gasket on the TSX (2005) contains two "wings" that contact the glass at two points. See diagram below. I prefer to apply felt (red) using method #1, but is this overkill? If so, what would you recommend?
cut the bottom peice of the gasket off then place the felt on it ...I do not have any problem w these cars at all!!!!!...if the felt doesnt stick rub it w alcohol..then apply felt....when pullin the door pannel off be carefull of the switches an the door latch!!!!..they will go back together just be carefull!...have fun tinting!!!
  • Replies 21
Guest staudy
I own a TSX and frequent the forums for it. I always bragged about using Madico and how it didn't scratch on mine. Well now I got the verticle hairline scratches as well. Most people that I have talked to have had moleskin added to it. Yes you have to pull the door panels off to get the moleskin on. Sux!!!
Heres a link to the door panel removal (not that any of the pros here need it:)
http://www.chrishorne.com/gallery/TSXspeakers
if they talk about their tint not scratching ...they r full of SHeoT....the problem is ur gaskets...they need felt buddy!!!!!it has nothing to do w the tint!!!
    3. 5
    4. 5
    5. 5
    6. 0
    7. 0
    8. 5
    9. 5
    10. 5
