05 Lincoln LS
finishlineautosports
  • Replies 41
car ended up being really easy, HUGE BG though.
Maybe you could post a little report about the specifics of the job then ??? :minichuck
or would you rather wait and watch the next newbie get chewed up ?? :lol
Well, I am still a noob myself so I don't like giving advice to others but....
All the doors are cake, don't even need to be shrunk. There is a screw at the top on the backside of each panel which needs to come out, pull back the top of the panel and remove gaskets. Just be careful popping the panel back on since these clips need to be lined up or you'll smash them.
BG is very straight forward with these since the 3rd brake light is up top. Just make sure you put in enough slip to slide the film behind the rear deck and you will not need to remove the rear deck.
**Also pay attention to the fact that these may have the factory amp right under the rear deck. I did not pull mine because I just made sure not to use a ton of spray on the glass and film, but if you like to drench the window, then maybe you will want to pull it.
One of the easiest cars I have tinted.
