need help with impala
painted600rr
If you're talking about the corners coming up while shrinking the tint, it's because of how hot it is outside. The water used to hold the tint in place is completely drying up. Don't worry, as long as you know it was shrunk properly, the tint coming up wont affect how it lays down on the inside. Just a little advice, when those corners come up like that, hanging the tint for peeling the liner can be troublesome. I like to hang the tint, and then clean the window of the car, but if the corners came up while shrinking, the tint will roll up and fall off the wall glass. Be sure and flip the tint where the liner is touching the wall glass. When you're ready to peel the liner, simply spray the exposed side of the tint, and flip it into the correct position for liner peeling.
Other than being a big bg it is a
very easy shrink. IMO it sounds
like you are over shrinking. :D
no the bottom is supposed to lay flat couldnt get it to stay down. im nopt using any heat
If you aren't using anyheat on the bottom of the BG you should be. Split the BG in the middle from side to side. Then shrink both top and bottom sections of the BG. :lol2
    3. 8
    4. 8
    5. 2
    6. 8
    7. 8
    8. 8
    9. 2
    10. 8
