PLEASE HELP! CORRECT PRESSURE SETTING FOR VE Q42
Guest Tinter10
Guest Tinter10
Hello All,
I have a Vinyl Express Q42 and I am having a hard time setting the pressure to cut tint. Could someone with experience on this cutter please let me know what setting code/pressure to set it at?
Thanks!
Is that the same as my graphtec fc8000? If so, I have the blade pressure from 14-17 depending on the film and how sharp the blade is. Speed usually around 25. I can get you the rest of the specs tomorrow if these are relevant to your machine.
Guest Tinter10
Hello:
Thank you for responding, I think it is comparable to the fc8000. If you could please send me the rest of the specs that would be greatly appreciated.
Thanks again.
