05 BMW 325CI
tntautoglass
back glass is simple. Panels are tight, but not too bad. The tops of these panels pulls back, not up, and they leave the rubber gaskets attached. These clips then pull up. It's easier to reinstall the gasket on the door, and then the panel onto the clips, unlike you would first think. I think there are only two fasteners to remove, and compression clips like most other DPs.
Guest VaTinterPMan
the panels on a BMW are not that bad to take off. The car itself is not that hard either. The owners of those cars can be a nightmare. Good luck. :thumb
What c2c said...I didn't pull the panels though cause I didn't want to take a chance and mess them up....I was going to push them down, But I taped them Back and slide behind than removed the tape...
