3 or 5 gallon corney tank?
I would use 4+ gal in a 5 gal tank.100cc slip. pressurize tank and using 30 or so psi thru the regulator get 25 or so 2 window trucks. My.02 fwiw
A five gallon tank, with three gallons of water, will allow for more pressure. Longer work time without re-filling and re-pressure.
thats where the regulator comes in handy.
For flat glass, with just a gallon of solution being able to do a lot of glass, is it worth lugging around the 5 gal or would a 3 gallon one be good.
3 gallons of solution would be more than a day worth of work....unless you use a ton of liquid while working... I can do 8 hours of auto and only use a gallon of slip or less.
