IWFA Regional Meeting, Arlington, TX (Competitions: Auto, Comm, PPF)
Push out all the air you can then… Heat up area with heat gun and use a hard card to press them down while everything is still fresh… don’t over heat prep work is key… you can also use masking tape on the gaskets and carefully peel the tape out once you have all the fingers out
