A class 2012
Tintsanta
ok start by removing the plastic insert starting at the end as shown.
post-34704-0-11979800-1405853378_thumb.j
remove 2 screws.
post-34704-0-24299400-1405853429_thumb.j
then insert plastic tool and slowly pry along the bottom and up towards the front of the door.
(clips are very tight)
post-34704-0-54095700-1405853619_thumb.j
then work your way up the rear of the panel till you hit this little tab.
post-34704-0-19585200-1405853742_thumb.j
you have to pull this tab to release the panel (and pull it out when you reinstall it)
now you can remove the gasket and hang the panel
post-34704-0-30043100-1405854022_thumb.j
i have found cutting down welding rods to about 5 inches and bending a hook at both ends work really well for hanging panels
    2. 3
    3. 2
    4. 2
    5. 1
    6. 3
    7. 1
    8. 8
    9. 8
