Included another pic of the door with unique push bar. I'm using a CDF film and also thinking about the caps to prevent air loss.
My concern is all the cutouts using a dark film with light gaps in all corners.
As for the plastic edge, I have installed vinyl on them before, in your case a silver opaque would be ideal or perhaps matte black, some of them are glued on and others are just held on by pressure.
A push bar like that could be a little tricky to R&R and you should add a charge for any handles you need to remove, up to you if you would want to add it in your quote separately or just give a price and say the R&R of the handle is included in the price of the door,
If you have trouble keeping your film close to the edge of the hinge and the corner piece, you could plotter cut some 1/6" matte black vinyl and cover them.
As for the round cuts I and one of the 8" 30/60 deg triangle circle template to cut out film close around the holes in the glass after you remove the threaded caps and handles.
