2014 c 300
jayson3st
Alright I got it done and was pretty easy. To get the sweeps out of the front doors you have to take off the trim that goes over top of the door. Plus the little tweeter panel. Once you get the top trim off you'll see a little square pop rivet. Pull out the middle with needle nose pliers turn it 90 then push it back in then it will all come out. Once it's out use something pointy to push the middle out again. You'll have to turn it back 90 to put the whole square back in. Hopefully that all made sense. Now just pull back top of panel to get to the sweeps. On the rears all you have to do is pull top of doors back. Sorry if this was confusing. If you get one in you should understand a little better
    2. 1
    4. 2
    5. 1
    6. 8
    7. 8
    8. 2
    9. 8
