Untucking tools
Guest naughtydog
  • Replies 34
Guest denvertinter
sometimes you need a slimmer tool to get into tight areas and this big hook tool will not work on those.
like the ladies say, size matters. :rollin
mdogs is the exact tool I use. It's called a radiator tool for removing radiator hoses off cars
I`ll be damned :rollin I knew this tool was used for something originglly but I wasnt for sure :beach
white Triangle Card Works the Best for me. YOU cut the WHite Teflon Card in A Triangle so you have 2 cards. if you wan to untuck the gasket. just Strat from your right side on your Passenger Door. and stick it in and pull it up. it wont Scratch the film, it wont peel or it wont chip the film. :jerkit
