any ideas how to do this window???
Guest fimmo
  • Replies 21
This window is quite easy. Do not shrink the bottom at all as with most cars that have a negative curvature at the bottom. Key here is upon applying the film to get each bottom corner down in one stroke with a big hard card or to hold the squeegeed part down with your hand and continue so until the whole corner sticks. The dot-matrix at the top if it is the wide one you should lift back off let it dry and reapply. It is known to release iron oxyde into the adhesive turning it brown.
This window is quite easy. :rollin
Try not shrinking the bottom, looks like it will lay without shrink, wet check it first though :rollin
td is right when you have windows like that. dont even shrink the bottom. if you do you will notice it will curl back on you when your trying to install it. ive found it is better to just leave it alone :rollin
