2018 E-class 220d wagon
BM-TINT
Hi. Had a brand new E-class in yesterday with 8km on the odometer.
I'll give some tips regarding the car.
Rear panels; lift the top up a bit and pull back. The clips are very tight so you may use some elbowgrease to get it of.
To be able to get the gasket out you have to pry back the plastic trim between door window and quarterwindow.
To get the gasket out, pull panel and trim towards you, start lifting gasket from the rear of the door(quarterwindow), twist and jiggle a bit and the gasket should come out.
These cars carry alot of electronics so be sure to cover the fusebox and the unit behind the fusebox with rags and/or releaseliner.
