Rear window removal
Guest Good luck!
I'm going to guess the old film was a commercial film and it had dry adhesive.  You can try citristrip or any other varnish remover but most likely if you have to go to this extreme, you're going to remove the defroster lines as it'll probably eat through the defroster lines adhesive.  Make sure you cover the heck out of the car and tell the customer you're not liable for any damage.
Guest Jed cowler
If you run the engine with the heated rear screen on for 5mins this normally soften s the glue enough to gently and slowly peel the film off without damaging the heated lines hope this helps 👍
