Do you dip your hands before touching the film?
  • Replies 32
Guest crewdog10
I don't touch the glue side either, peel liner and then hang on your arm and roll film on to glass I do this with such ease that it would blow your mind for not doing it. watch a friend of mine do this and just started to try it and now it's the only way I do it, been doing it this way all year and no finger prints.
:lol6
Guest Eclipse
I dip my hands in a five gallon bucket of water right after I peel the film. Quick dip and then grab the film and hang it on the glass. :lol6
Guest nautiboi73
I used to sometimes have a problem with finger dirt, so I just don't touch the adhesive anymore. Just pinch and never worry about dirt anymore.
works for me.
Guest BigZ
I Bought a bucket at Home Depot for like 4.00. I fill it up with water and all my tools when tinting. so after razor the window I give each squeege pass after diping it in water and shaking a lil bit. and when don I spray it and take the liner out spray it and then soak my hands in water kind rinse it and then touch the film. it take a total of 2 mins extra on each window but works Great. :spit
Guest autotintplus
If you use a board or mirror like I do:
1-lay the tint up on there
2-spray off hand (L) if you're right handed
3-spray bottom 3-4 inches all the way across
4-spray corner of side you're peeling
5-use finger nail(s) and scratch til the liner comes loose(takes me 3-4 seconds)
6-spray that corner down so it stays while you peel liner and doesn't buckle/crease
7-peel liner til part that's wet will hold it down
8-spray entire film
9-spray both hands again to re-wet
10-grab film w/ both hands
11-walk w/ film facing you ( adhesive side)
12-Lay film on window - tint as usual, Done!!
Only learned from the pros.
:spit
Guest cool
I use a kitchen worktop against the wall as my cutting board and to peel and spray my film with.
I touch only the two top corners and as these are then pushed into the corners and above the top of the glass nothing shows anyway........but if I do get any specs of dust its in the glass :spit
