mid 70's thru mid 80's corvette
hoosierwindowtek
Definately back roll it, if it is a 79 -82 the seats will lay flat if pushed all the way forward giving you lots of room to work, if it is a 78 you might want to remove one of the seats to give you some room, if you are planning on doing it it one peice it will probably take 2 trys so price it with that it mind. also remove the plastic tray running all the way around the bottem of the rear window. :spit
Funny I just tinted one this weekend and yeah it was a biatch. One pieced it no problem except when you have to lay the film on side it kept curling up on me, but a litlle heat from my heat gun did the trick. Car was so filthy inside. Must have lost a few pounds with all the sweating.. :bling
I still prefere doing these in 3 peices ...2 end peices up to the defog lines..1 big peice for the defog area...no hassles..never have them come back from over shrinking over the yrs.
Not THE way..only A way :shock
