low e detector
Guest tallscott
Look you can still bid the the job now! Just mention you need to verify if the glass is Low-e before you install! You can get a meter over nighted and have it tuesday. Mabe $100.00. Just go back, test the glass and order the film. Get the job first, then check the glass. If the meter says #3 back away, Don't start off with trouble. Its not likley, but cover you rear always. Most people understand when you explain! I always test any window for low-e with a meter. It takes seconds, makes you look cool and covers you rear. I don't trust what other people say who aren't at more risk the me! Get the job!! Check the glass! Build in the meter!
Or you could just read the label. :dunno    It'd be nice if all windows were this easy to figure out.
Between looking at the glass, window markings and the customer letting you know, you should be able to catch low e
[*]338630
Saw one once where the glass was put in backwards, arrow pointed outside and it wasn't Low E2... Even the glaziers don't look :gasp
[*]338638
you'd be amazed on how many times I've seen that :bs
