2005 Focus
jj
Is anyone else having trouble with film not sticking to the R/S dot matrix in the current model Focus?
I know its that old "matrix" chestnut!! I dont usually have any probs on other vehicles.
Thanks again Henry :beer
Guest autotinter
yes I have had problems with it sticking to the top of the back glass. just used a bit of glue, it worked fine. but thats the only car I have that problem with, both the wgn and 4 door :ohcrap
Idid a post on this a while ago...all you have to do is take a very small peice of wet sandpaper grit 600 - 1000 (both will work ...I use 600) wet scuff the dots ( be careful not to scratch the glass surface ...for more accuracy use the tip of a plastic push stick to get more accurate scuffing)
It only takes a minute and will solve any and all Ford peeling problems on perimeter dots.
Hope this helps :ohcrap
Hey thanks everone, I will try the wet and dry paper Wiz, have used this method before on retail work, I guess working as a sub contractor im looking at speed but your right cant take too long. :spank
