Liner for felt shields
Guest clear image
  • Replies 32
Guest streetsounds
I've tried a lot of ways to install film without debri, especially those pain doors  Taurus, 97' ish Impalas. Until now. Using liner sheets. Clean glass as usual, then with glass an inch or so down, cut a left over liner sheet the height of the glass on the inside, from the bottom door gasket to the top of the window and about 18" long horizontally. Lay it on the inside that way with the rigt side of it laying overtop the right verticale door post and the reat still on the glass. Now tuck the right side in with a bondo squeege, lil chizler or whatever you choose, between the glass and the right verticle door trim. The liner sheet is now laying on the glass and behind the right verticle door trim. Take the left side of the liner, lift it off the glass and rap it around the right verticle door molding from the inside to the outside laying it now on the outside of the window and at the same time keeping the tucked part in place. This seals off the felt. Do the left side the same way. Flood both sides to remove any left over residue, squeege, myst again and install. Once finished just pull liner that is still tucked between the gaskets and glass. DONE!  No fuzz... no fuss. Try it.
[*]326227
