If the customer had there glass replaced in there vehicle would you charge them again or tint for free?
22 members have voted
Steer clear of Black Armour, Suntek, ASWF. The others are good choices if you are in Australia. Check out the reviews of the installer too. It’s not just the materials that have to be proper. Never go for the cheapest!!!
