Chrysler 300 05
Guest swanny
Does any one know if the radio antenna run throught the rear window on a chrysler 300 2005 .
I installed sunteks hp film on the rear window and they say they are having problems with the fm reception? :spit
Any one run into this problem on this car?
Even a slight cut in the defroster can give you reception problems
1. Did you 'seam' or 'two piece' the rear window?
2. Does the reception totally go out when you turn the defroster 'on'?
If you answered Yes that is most likely your problem
    3. 5
    4. 4
    5. 5
    6. 5
    7. 0
    8. 0
    9. 5
    10. 5
