2006 Civic Coupe
Guest Al-tint
  • Replies 20
20% back 3
top matrix vinyl
HOLY CRAP I tinted one yesterday and that back window will be almost impossible to squeege at the bottom unless you have a bulldozer......it gave me hell WITH a bulldozer.
got any tips on how to take the rear deck out AL_TINT :beer
Guest Al-tint
20% back 3
top matrix vinyl
[*]353299
Taking it out is easy, putting it back can be a PITA. BUT it is way better than the other years where you pulled the seats and walls.
Lay down seats.
Remove two screws.
Take a prybar and insert it up under the plastic deck by the screws and push UP to the roof. There are pins/clips MOULDED into the deck and you can see them as dents on the face. I think there are five. Push UP on each.
Now take the prybar and slide it under the deck and POP 4 white push pins that are located near the curve down the seat.
PULL deck to the front of the car.
4 white push pins will be left in the metal. Pop them out and insert back into deck.
Cover speakers and sub with scrap tint.
Tint.
Remove scraps.
Now the PITA.
You have to get the deck in real tight to the glass to get the back push pins in. The centre two are okay, but the two on the ends are a MAJOR PITA to get.
Pop in the front ones. Now work the moulded pins/clips back into there spot.
Replace screws.
:beer
20% back 3
top matrix vinyl
[*]353299
Lay down seats.
Remove two screws.
Tint.
Remove scraps.
Now the PITA.
Replace screws.
:beer
[*]353333
Sounds easy enough.
I can't stand having to pull back decks, but sometimes you just gotta do it.
Do any of you guys/ gals charge extra for that or just chalk it up under the it had to be done to do it correctly category?
    2. 1
    3. 2
    4. 1
    5. 8
    6. 8
    7. 2
    8. 8
    9. 8
