ppf 06 350Z
Guest ShadyKat
Guest ShadyKat
06 350Z
There is not a Deluxe ClearShield kit out for this car yet and I was wondering (after looking at an 05) if anyone has attempted to use the 05 pattern. I looked at both of them this afternoon and the only noticeable difference was the dip in the center of the lower cross piece and the 06 was set back at a sharper angle. Basically nothing that two snips with a pair of scissors and adding a little extra material on the lower cross piece for some margin of error, which could be easily hand trimmed. The standard kit is the same for both years and the customer is really wanting that lower facet covered. Any suggestions would be helpful.
Thanks
:beer
If this needs to be moved to vehicle section I understand.
Guest ShadyKat
tried it, too short and the parking lights are different too. and top edge is slightly off, as well as the middle lower section (like you said).  so, it kinda fit...
[*]385301
Thanks for the info, :wtf decided to hand cut the bottom bumper, (this should be fun) :dunno
