Ok so here is the scenario
  • Replies 42
Guest dumplin
Use a vacuum , peel carefully and spray it out or . Make a relief cut as close to the contamination as possible and use some fine tweezers , carefully squeege with a yellow turbo and a little heat . Has worked in the past w/o redoing whole back glass .
Guest tint rookie
set sprayer to blast.
pull that film back, shortest distance possible.
red dot wit 30 degree blade (all I use it for), pick that bizzo up outa there.
flush the heck outa it, take two.
try not to take one out and put two more in.
Guest pmuzik
And honest...
I was wondering who would be the first and if they would be honest :bingo
:thumb
[*]402520
I don't know about back glass's but when that shiot happens on a flatty job the FIRST thing I do is say WTF over :thumb you said honest right
I'd try to fish it out with the above methods TTC..and then make a choice based on the car and the customer if a discount would be in order because it's an easy going customer with an older car that has other flaws in the glass or if it's a newer car, no hesitation, bite the bullet and redo ..whatever makes the customer happy ..or your conscious :thumb
