madico...
Guest Texasrocker
Thanks for the professional opinions! My point "exactly"!, the Pro Tinters said the same about the early Madico TG series auto film. But it outlasted Madicos "Hybrids" by a long shot! Believe me, I applied this to my own shop truck, just to test it. The adhesive system is OK, but ya gotta back-off on the soap installing it, or it tries to slide all over the place. It Does "match" , factory shading, but we will see how it holds! Thanks Pros!! TR
  • Replies 20
soooo what you're saying is you're going with the jet series then? :gasp
I used that TG..and the AG..for years..and I have seen the results of that film ..and from what I saw of it...it wasnt good
I came to the same conclusion :gasp
Guest tintdawg
Most of Llumar films are 'atr and at" Llumastar would be 'atr35ls' Stelth would be 'atr35st' high performance would be 'atr35hp' Jet is just 'jet35' looks good at first but fades fast. RED LIGHT WARRENTY. IE; At the first red light, your warrenty is over!
Guest Soultinter
If you are use to using TG then you are also used to using a fairly thin film, from the sound of things, you should be using the AT35LS.
    2. 5
    6. 3
    7. 3
    8. 4
    9. 0
    10. 6
