tips for tinting vent windows in a ford pickup?
Guest smallblock351w
one tip would be that you can cut the rubber out a bit to make more room to slide the film into on the edge of the glass. I just notch the inside and use the outside to cut it. Round off the corner points. Use the clear edge of the glass to cut that side and when you take it to the inside of the glass, window open it will slide back slightly due to the notch. Should lay down wonderfully.......
hope this helps
    3. 5
    4. 4
    5. 5
    6. 5
    7. 0
    8. 0
    9. 5
    10. 5
