nissan rogue
Guest dumplin
Guest dumplin
Just 2 frd's , really simple for panel pullers , 3 10mm bolts , silver ,plastic cover on door pull , 2 bolts underneath , 1 bolt under door opening latch . front glass ez , but has a strange mirror , looks a little Fordish , didn't remove as it bent down enough to cover 6 inch legal length , no as1 mark .
Yep, i wish every car was as easy as this car. Super easy.
no reason to pull the whole panel... the top will pop back probally a inch.. more than enough to get the tint in.. just make sure the get the plastic door tab back in the hole so it dosent stick out... if you hear a loud pop on the first few you do like this, its the plastic piece near the latch on the door.. very easy to pull back, harder when its cold though...
