Super Glue for minor cuts
If you get a minor cut while tinting and band-aids aren't practical because they will get wet, you can always use a small amount of super glue (ethyl cyanoacrylate) to keep the cut closed and clean until the job is done.
Hold the cut closed and apply a very small amount of super glue along the cut and let it dry. Try to keep the glue on the surface and not in the cut. This works in a pinch, but it may irritate the skin, and should not be used on a deep cut.
There is even an antibacterial version of super glue for this very purpose called Dermabond.
  • Replies 21
Guest filmslayer
hey TD , here's a pic of the thumb I had taped today, I did this some how trimming a edge with my red dot . I figure seeing how I finished the window before I taped it and it's on my drinking hand it should be worth another purple hart ! :nope
:nope
Guest thatsnappyguy
dermabond is what is used in the emergency room over here for monor cuts. although its much more simple than stiches, it still cost about $500. to close a 1/2 cut. I saved myself about 6 trips to the ER by just using regular krazy glue.
    4. 2
    7. 4,178
    8. 1
    9. 4
