In the Hood, you dont need jacks to work on your car,
Dano - thanks for the input. Like I mentioned, the drivers are no longer available online or through Graphtec. I found a company "DriverGuide" online that says they have the most current drivers called "Graphtec FC4100 Driver Update Utility" they swear it fixes common communication errors, printer head glitching and operates on Windows 11 - they want $30 for a 3 moth subscription to their data base and claim to have the driver but I have also heard there is the possibility of using either another Graphtec driver, or also depending on the cutting software the driver for the plotter may be included in the software. I know FlexFilm's cutting program supports an FC4100-75 but have never seen a review on their software, its capabilities/functions, or its overall accuracy. I do not want to trash a perfectly good plotter. So I am not just going to jump into buying another plotter if I can get the one I got for free one working. It was working fine with the previous owner for vinyl sign making, stenciling, and window tint I watched it work. As much as I would love a newer FC Plotter, there are cheaper options out there that compare and will work with my current computers.
