85 Camaro
Guest Scuba
Guest Scuba
I have an 85 Iroc in the shop. Are they different than the 91' mentioned in a previous post? Looking for some advice. Tried to dry shrink, the bottom corners get to tight and pull the sides up. Should I leave the bottom with no shrink and move fingers to top, then shrink the top? there are no defroster lines so I want to do 1 piece. frustrated!
If there is no defroster, just cut it out , slam it up there , have a heat gun at standby for the bottom corners. watch out for the struts when you put the film up. That is a 15 minute rear glass.
Take it to a pro........ :spit
if you are telling him to take it to a pro, then does that mean you are not the Pro???? Otherwise you woulda said BRING it to a Pro
:money EASY rear glass. Done hundreds of em, never shrank one.
    2. 2
    4. 8
    5. 8
    6. 2
    7. 8
    8. 8
    9. 8
    10. 2
