rear view mirror 2011 Ford Fusion
Guest arcwindowtinting
A) cut around if you are in doubt
B) there is a little tab with 2 "teeth" on it that you can gently pry open and slide the mirror up. you have to pry against the glassand it doesn't need much, I don't think the teeth are even 1mm tall. The clip is sort of like a spring, so pry it a little and slide the mirror up.
    2. 1
    4. 2
    5. 1
    6. 8
    7. 8
    8. 2
    9. 8
