Top quality 48 inch or larger printer
Ready to invest in a printer for banners and such, that does full color, pictures, whatever. I want to find the best, prices seem from 15,000 and up, which is fine. Any of ya'll have one and what do you recommend?
Thanks- Danny
I'd go with Roland VS series if I had enough work for it.
A friend of mine has it, and prints stuff for me when I need it. I love how the prints look.
I'd take a laminator too, to protect those prints for wraps.
+1
Definitely will need a laminator for any prints you would want to hold up outdoors. So add another 5-10K depending on the size of the laminator
Guest cooltouch
Latex HP L25500
bigger ML tanks - 775's
cheaper on ink and last longer
instantly dry
been using it for 2 months now. It takes a bit of getting used to but I will never go back to a solvent printer.
Latex HP L25500
instantly dry
The Roland versa camm is also a cutter! The Mimaki printer is like the Latex printer and for just printing there the shiznay!
Roland is top notch no doubt. In regards to a laminator , it depends on the print. Rolands Eco sol ink is rated for 3 years outdoors with no lamination. Laminating is expensive, and as long as you are up front with your customer, many want short term signage , minus lamination, even on some big prints . We are running a Sp-300 and a SP-540, and they are truly work horses . Im eyeing the new 64 coming out next month .
looked into buying a printer once too . But it is very time consuming designing printing laminating maintaining the machine . You can can wholesale avery laminated for $4 a sq ft . Alot of people are stuck with $5-800 leases with no work to pay for it . And you know how cheap people are now a days to fork out $2500 . :thumb
Just be sure you have enough work to run it every day. These printers like to run constantly and you will have a lot of headaches with clogged heads if you don't use it enough. I have a 36" and a 62" Mutoh myself.
    2. 1
    3. 6
    4. 2
    5. 2
    6. 2
    7. 3
    8. 6
    9. 1
    10. 0
