Did my first Beetle yesterday!
Guest l1ld3v1lrydr
Guest l1ld3v1lrydr
First Beetle, first try! I can not believe I actually got it come out almost perfect! Never had anything in that had this much curve to it! So stoked that it came out! Had to do the pass door 4 times til I was happy with that lol! Used powder with it tacked only across the center, lots of heat and lots of pulling!
Guest l1ld3v1lrydr
I ended up pulling the panels. Only because I kept getting little fingers that kept popping up. Even after snapping it. Put I wasn't aware of the side seals coming off. Though I dont really recall having a problem with those. I cut the window like normal and then put all the fingers on the bottom and shrank em all out. One of the times I had to redo was because it creased a little on the bottom. So I redid it one more time lol
