2000 Camaro convertible question
mustangdroptop96
It's a small window but hard to cut out from the outside because of the convertible material. So I cut it big and tried cutting from the inside but kept getting contamination. Thought it was going to be an easy job but I was wrong lol. Any tricks to do these? I'm debating ordering pre cut film thinking that may help? Any ideas?
Do that again with a sacrificial piece. Squeegee it all out good and then pull it off. The borders will be evident on the adhesive side. Lay it up op your peel board over a new piece. Cut trace it exactly how you need it. Shrink n stick. Spray less inside the car and more for the peeled pattern.
Keep the successful liner and label it for future Camaros.
