TintSlime & Slime Swag Raffle 7/30/13 - 8/14/13
Graphtec Plotter
4,178
What did you tint today?
Thanks for the reply! I will see what happens. I tested the paint on a scrap of PPF I had sitting around, the it seems really secure. Just for perspective, I attached a photo of my goof. It really was a small divot, just bugged me that I did it at all. I did place a very small bit of paint on the top of the exposure. Living in MN, rust is always the concern, so I am hoping I have this sealed. While I know that PPF can't heal a cut like this, it was very flat so the exposure should hopefully be minimal. (What looks like a fold is the reflection of a seam in the ceiling)
