How much J&J is to much.
Prety much I like to know what happen wen  I have extrasoapy solution , Besides the problem of the film moving around to much , I had last day some white marks kind o when a soap buble hits a glass  surface and leaves the mark when it pops. I tried this because it was hotter than normal and film was just stiking to the window I couldn't even get to position film properly Thank you.
I think i know what you're talking about. I think that it is more of extraction of water rather than slip solution. Make sure you're talking about a half a blade each time you push water out. Also kind of angle the blade as to push it the direction you're moving. How much slip are you using?
I use 6 ml. Of shampoo or baby wash it comes out to aprox 2 tea spoons on a 1500 ml. Sprayer . the time I used more than that it foams to much on the bottle I need to find the way to get more slipp with out so much foam. That won't let solution come out of the sprayer .
