jj Posted October 31, 2014 Report Share Posted October 31, 2014 Hey slingers, we have some 20+ year old tint to remove and replace. Usually we would just hack away with SS blades, I was wondering if the carbon or heavy duty in the triumph range are any better at keeping their sharp edge for longer? Link to comment Share on other sites More sharing options...
Tint Eastwood Posted October 31, 2014 Report Share Posted October 31, 2014 The added risk of scratching doesn't seem worth it to go with the carbon steel, even though it will likely keep a better edge. Never tried the heavy duty blades but I would assume they are just heavier gauge, so what you gain in durability you'll likely lose in overall sharpness. Personally I'd just grab a couple extra packs of regular SS triumphs and go animal on it. Link to comment Share on other sites More sharing options...
TomTint Posted October 31, 2014 Report Share Posted October 31, 2014 We actually use carbon ones every day. Only time we ever scratched glass was on grainy tempered, which would scratch with SS as well. Old DA film will eat triumph blades pretty quick regardless which ones you use. PS is usually pretty easy. On tough DA removal jobs, we have used 4" scrapers with metal handles for leverage. Those also tend to gunk up and dull fairly quick. Link to comment Share on other sites More sharing options...
Tint Eastwood Posted October 31, 2014 Report Share Posted October 31, 2014 I don't trust carbon blades. We change out way too many panes that have been scratched by contractors or painters trying to clean the glass. The only common denominator in each case was the type of blade used Link to comment Share on other sites More sharing options...
WearTheFoxHat Posted October 31, 2014 Report Share Posted October 31, 2014 I use 4" Ungers on film removal projects and save the Triumph for the final clean and for nekkid glass cleaning. Your mileage will vary but 4 to 20 square feet per blade. With some types of film the blade will go longer. Link to comment Share on other sites More sharing options...
wickedtint Posted November 1, 2014 Report Share Posted November 1, 2014 I use 4" Ungers on film removal projects and save the Triumph for the final clean and for nekkid glass cleaning. Your mileage will vary but 4 to 20 square feet per blade. With some types of film the blade will go longer. same here Link to comment Share on other sites More sharing options...
Thirtyfive Posted November 2, 2014 Report Share Posted November 2, 2014 I understand the theoretical behind the carbon blades scratching, but I honestly think the only advantage to ss blades are they will take longer to rust. IMO all blades will scratch if used incorrectly and all blades won't scratch if used correctly Link to comment Share on other sites More sharing options...
RockyDaz Posted November 2, 2014 Report Share Posted November 2, 2014 I understand the theoretical behind the carbon blades scratching, but I honestly think the only advantage to ss blades are they will take longer to rust. IMO all blades will scratch if used incorrectly and all blades won't scratch if used correctlyYep, agreed.The ss thing is more of an issue when talking about Olfa blades and cutting glass IMO. Link to comment Share on other sites More sharing options...
Epic.Tint Posted November 2, 2014 Report Share Posted November 2, 2014 I did 3 big removals in the last 2 weeks and I've always used the carbon. I decided to get the SS to see if they're better and they were only good for the initial film removal as it catches the film nicer. Also I put the scraper on a 3' metal pipe the is used for running electrical wires. But when it comes to scraping glue the carbon goes a lot longer. Link to comment Share on other sites More sharing options...
