which films have the largest shrinking capability.
Yeah, dual-pane glazing units can fail at any point in time from day 1 and up. It's rare in the first couple of seasonal cycles, but you never know until it shows itself. Dual and Triple pane systems rely on the seal between glass and spacer. Even there they can have a single seal; glass to spacer, or a double seal that wraps the outer edges and seals (encapsulates) spacer and glass as well. The latter is found in high quality glazing systems. The former brings trouble before its time. The gas or dead air space between the panes has zero to little impact of failure of seals. Once a seal is compromised (for whatever reason), moisture intrusion occurs. It can be visible to the eye when cool and it can be microscopically invisible. What produces the visible lines, smudges, spots, etc. is the desiccant (located in the spacer to absorb any minute moisture). Kind of like the dry packets used in shipping goods. Desiccant gets wet, heats up to vapor from sun exposure, it deposits on the interior of the system and once the sun dries it, you get a number of different aforementioned looks; some obvious, some not so much until film is applied. You can have the one sash replaced, either through warranty based on seal failure or by out of pocket cost. Be sure you let the window folks know the other panes do not display the same as the one in question. They have a tendency to baselessly blame seal failure on applied window film, which our industry has dispelled through long term studies using the 'right' window film for the system. Good luck
