2016 BMW 750Li
CustomGlassTinter
2016 BMW 750i
Thanks guys, pulling the rear seals , and unclipping the 3rd brake light made this job a breeze,...... Taping the felt and prepping the vehicle took 2/3 of the time.   Not a difficult vehicle but it demands being clean and meticulous.
Edited by shockswindowtint
make model year vehicle
oh man....why did BMW did this...."They hate us tinter" .... I am uploading some picture of what to remove on this model.  Even though you remove it, good luck on doing a very clean install.  It is not a easy clean drop if the car is not prep right. We charge an additional $50 for this model. We explain to the customer our procedure on installation and why we charge the additional $$$$......and guess what ?????what....they all leave it with us!!!! This model is not hard just so time consuming to do a clean install.....Them $99 tint shop are not doing this...Not a profitable model for them to make money.
The back door is easy to take out the sweep. Just pull on the cover and hook out the sweep.  The front door.....pop out the cover behide the door handle and remove the screw. Then....pop out the long light trim and remove only 1 screw...after you pop it out, pulled it toward the back of the door to remove it.  There are 3-4 little clip as everyone mention but if you do it slow....You are ok.  Also....put more J&J or what every you use in your bottle...you will need room and time to wiggle on a hot day. THAT ALL FOLK......
Edited by Midtown Houston
