Kia Sorento speaker damage?
Captain Obvious has two cents err senses to share: 1) The film should be removed and replaced, because it appears to have adhesive blemishes that shouldn't be there, and 2) The film should be reviewed/inspected once taken from the roll to avoid losing time and resources due to manufacturing issues. Little pieces not so much, but back glass and windscreen pieces ... definitely. -
By the way how much coverage would I achieve from 1524mm x 3000mm (i.e. 60" x 118") -
thanks for the input, going to try the nt blades -
