TSER between Architectural and automotive films?
![Guest Slime](http://content.invisioncic.com/r47004/set_resources_81/84c1e40ea0e759e3f1505eb1788ddf3c_default_photo.png)
By
Guest Slime
Looking for a tinter with experience in the trade, willing to pay $1,500-$2,000 salary based on experience. We are a high-volume shop working with updated equipment and highest quality materials, you will be working alongside an experienced tinter to complete each vehicle All film is cut by plotter Monday - Friday 8:00am - 5:00pm Saturday 8:00am - 3:00pm You must bring your own tools and are required to show up on time and complete work in a timely manner Please call and ask for Ronnie 619-339-2211
