04 vw jetta
Guest RED
this isn't THE way...but A way :
3 bolts under pryed off child seat clips...tray slides out (a more detailed post on that on here somewhere...most likely Jetta forum :dunno )
That's for deck removal
I tuck the rear door rubbers (one of the few because they are sometimes stubborn to get out...remember to untuck them later :rollin )
front doors I remove gasket (I don't pull the doors on these , I pull the upper panel off and away from gasket :rollin
Just remove the screw on the front top of door panel (on doorjam side). The top of the panel will pull up and back plenty enough for you to remove the gasket. On the rear doors I remove the entire panel. If I'm feeling lazy then I just tuck the seals on the rears. Like TW said, those rear gaskets can be stubborn.
    3. 5
    4. 4
    5. 5
    6. 5
    7. 0
    8. 0
    9. 5
    10. 5
