'72 Chevy Pickup
Guest d03boy
Guest d03boy
Is there anything special technique I need to use on these windows? The back window is obviously just a flat glass panel, but the rollups move backwards while rolling them down. This seems odd to me and I'm not sure how to go about tinting it to line up the edges. (There is not two sidetracks, just one I think)
Any information would be appreciated. Thanks
...Joe / d03boy
Guest d03boy
Ah yes, Ive read that before, I just didnt realize that was what its for. I dont fully understand those directions though. :(
Thanks for the link TD
...Joe / d03boy
Guest Sprinter
what I do is put film on line bottom up tack down, then cut the tint by the mirror the hole length, roll window down till you can see the edge twords the bed then cut tint on edge of window as far as you can go now carefully pull tint outword on top an roll window up and then carefully cut rest of tint off the glass in the same direction and the metal door goes. when installing it just slide it twords the mirror side 1/8 inside felt, finish window like you normally do, you'll end up with a 1/8 to 1/4 off the back side and no light gaps.
