39 chevy
pierce8468
like most old cars this one is a pian in the rump. but ill see if maybe I can save anyone who has to do one a little headache. the back of the doors are rounded. and you have to leave a little extra at the bottom the my best suggestion would to be do one door . and if it fits just use the liner as a guide for the next side. this is how I did mine I left about an inch extra at the bottom. I cut the front side first then slide it ove a 1/4 inch. then I rlled it down as little as possible. so I could get as much of the curve as I could.then I took it over to my peeling glass and tryed to cut the rest of the curve by hand. the first one I did . I cut the curve a little to much. but the second fit sweet. when you do the back and the quarters. cut them a little bigger. because you will have light if you dont. the and there is no room in the back to do the back glass. its only a small window. but tough to work on because of the tight space.
